Survey123 geopoint default value
2748
11-15-2017 02:59 AM
CodraFrum
Hi there, is there any way I can set an initial (default) value for @geopoint?
the opposite of pulldata() ....
Thank you,
Codra
IsmaelChivite
Esri Notable Contributor
Hi.  You can set a default value to a geopoint question.  For example, you can set it to 43 -117. There is a  brief description about this in the blog post https://community.esri.com/groups/survey123/blog/2016/06/08/calculations-on-geopoints
If setting this value using Microsoft Excel, note that you may need to add a single quote ' before the coordinate pair to avoid  Microsoft Excel interpreting your text as a formula.
