Is there the option to make copies of surveys from the Inbox such as there is from the Sent folder?
850
10-25-2017 07:44 AM
KevinKozak
We have created a survey form from a hosted feature service. In the survey, we are using the Inbox folder to load the current features. These represent previous year’s inspections and we would like to edit a copy of the survey to maintain certain information. It seems that the only way to create a copy of a survey is from the Send folder.
Having only one option to create copies of surveys from the Sent folder creates a difficult workflow. It seems you would need to open the survey from the Inbox, save the survey with no changes, and then send the survey from the Outbox. After that, you would create a copy from the Send folder, edit the survey and then send the edited copy. It would be an easier workflow to be able to create the copy directly from the Inbox, make the needed changes, and then send the updates.
by Anonymous User
Not applicable
Hi Kevin,
Currently this is not supported and there is no option to create a copy from Inbox. The workaround you have suggested would be the best option, open the survey, submit with no changes, then create a copy from Sent box.
We already have an open feature request to copy from Inbox in our backlog so I have added your comments to this issue.
Regards,
Phil.
KevinKozak
Thank you for your reply Phil. This will probably make us rethink using Survey123 for our Bridge Inspection application. Is there a time estimate of when this enhancement will be addressed?
Kevin
by Anonymous User
Not applicable
Currently we do not have a time estimate for this enhancement.
Phil.
