Survey123 functionality: calculate position in repeat group?
21048
24
04-07-2017 02:55 PM
MaxMarno
Is there a calculation that will return the index or position of the current repeat set? This would be useful to pulldata and populate the default answers for each of the repeat questions based on the position in the repeat index.
NicolasPfeffer-Taggart2
Thanks a million Doug, it works like a charm!
NicolasRoger
Good solution Thomas! Your answer should be pinned to the top so it is made visible.
MarkC1
Has anyone got this to work in a web form? Seems to work well in the app but it doesn't work in the webform
LeZu
I'm having the same problem..
by Anonymous User
Not applicable
It would be nice if ESRI were to provide the autoincrementing option/solution with a caveat to caution surveys with multiple users.
