Survey123 Formula
650
04-12-2018 12:44 PM
TKSHEP
Is it possible to use a statement if 1 or 3 items were selected on a multiple list select to allow a user to type a number value in.  For example if I have Retail Stores as a label and the choices are: Walmart, Target, Sears, Kohl's, Best Buy and then if the user selects Walmart, Target and Sears a box will show for them to input a dollar amount of an item.  Showing that the stores with a dollar amount had a tool they were looking for and the others did not have the tool.
JamesTedrick
Esri Esteemed Contributor
Hi Trisha,
Yes, what you are describing should be possible using Survey13 Connect.  There is a function, count-selected(), that provides the number of choices that have been selected.  Additionally, if you need a question to appear when a specific choice is selected, there is a function, selected(), that will check if a value has been selected.  Formulas—Survey123 for ArcGIS | ArcGIS provides more information.
