Thanks for the reply. Yes, I have already registered the app id for
survey123 connect using the website you mentioned.
I found out a way as a workaround(definitely not the right approach). I
mention a wrong url (the portal url with a typo), ignore the ssl, it asks
for domain credentials, use my credentials, then replace the url with the
correct one and add url. Then it works.
However if i just add the portal url and ignore the ssl, it gives me
invalid client id 500.
With Regards
Srinivas Santhanam
