Survey123: Fillable empty rows?
755
06-16-2025 10:08 AM
Babcock_Kristen_L
Hello all!
I'm wondering if there is a way to create multiple empty fillable rows yet in Survey123?  It's important that the field staff be able to see what numbers they get in previous recording because they collect a sample when the numbers have leveled off. Below is a snapshot of the form I'm trying to create.  Thank you very much for looking!!
2 Solutions
Neal_t_k
MVP Regular Contributor
Currently you wouldn't to reproduce this type of table form.  However you may be able to achieve the same functionality by using a summary section, followed by a repeat section with the questions you want answered at each visit.
https://community.esri.com/t5/arcgis-survey123-questions/create-a-summary-page-within-my-survey/td-p...
Here's the quick basics, then there is lots of things you could do to make it prettier.  Make sure you make the bind::esri:fieldType null if the collated fields do not need to be stored.
You may also look into the pulldata @layer function if this doesn't meet your needs.
DeonLengton
You cant really recreate that tabular format for capturing in Survey123 but as Neal mentions you could create a summary section to review the captured data. This works well with html tables as you can see below:
Neal_t_k
DeonLengton
