Survey123 Feature Report Template Error
1958
7
10-03-2019 03:45 PM
RickeyFight
I am getting an error when trying to create a sample template.
Survey123 for ArcGIS
Tags (1)
JamesTedrick
Esri Esteemed Contributor
Hi Rickey,
Are you using ArcGIS Online or ArcGIS Enterprise?
RickeyFight
James Tedrick
I guess that would be helpful information.
I am using ArcGIS enterprise. I am also created the survey in survey123 Connect
JamesTedrick
And to check, the ArcGIS Enterprise implementation is reachable via the internet, which is required for the feature service functionality?  See Use Survey123 with ArcGIS Enterprise—Survey123 for ArcGIS | Documentation for more information.
RickeyFight
James Tedrick
Yes it is able to reach the internet. I started one before on a similar survey but for some reason I am getting an error this time.
JamesTedrick
It might be best to open an Esri Support ticket to further diagnose what the issue might be.
JordanMiller4
This might be a "public facing" issue with your portal. I would recommend reading the documentation and having a word with your IT.
https://doc.arcgis.com/en/survey123/reference/survey123withenterprise.htm
RickeyFight
Jordan Miller
I can create a report using a different survey. I am not sure "public Facing" is the issue.
