Survey123 Feature Report From a Web App
2444
05-05-2020 01:51 PM
joerodmey
I'm looking to add some functionality into my workflow. Just to set the stage:
  • Road inspection data was collected via Collector
  • Want to create a "package" for a contractor to fix the identified deficiencies. This would include a simple map and report (report is more important than map) displaying the locations and the associated data with each deficiency point
  • Say a user wants to select selects 5 points from a AGOL feature service. I need a way to select these points (Maybe through a web app builder app and the select tool). Now the user will need to create a report for each of the 5 points selected. This report would just show the attrbutes for the selected points
Maybe create a report into Survey123 via an open ended webhook through Integromat. This will all act on a feature service tied to Survey123 and spit out a feature report from Survey123. I'm not looking for anything fancy or complicated. I'm just looking at ways to allow the user to select multiple features on a map and export a report on them including data and any attachments.
Thanks.
JamesTedrick
Esri Esteemed Contributor
Hi Joe,
This would be possible to develop in a custom app (or a custom widget for Web AppBuilder/Experience Builder) by using the Feature Report's REST API resource. Documentation for this is available in the Survey123 Beta Community.
joerodmey
Do you know of any examples from ESRI or the community of this?
Can multiple inspection results be put on one page of a feature report?
PeterMacKenzie2
I also have a need for this. However, in the meantime can any AGOL user generate a report via the Survey123 website by clicking through to the data tab. ie. https://survey123.arcgis.com/surveys/3...3/data ?
ChrisCzerwinski
Will using a custom widget to run a feature report template through WAB still consume credits?
