Survey123 Feature Report | change symbol on map to point in the direct the photo was taken
1632
04-26-2022 01:54 PM
MichelleWilliamsERM
I want to take this location image and have the arrow point in the direction the photo was taken. Is that possible?
Thank you for any help you can provide.
ZacharySutherby
Hello @MichelleWilliamsERM
There are a couple of options:
- The Survey123 Report Template syntax does support a rotate parameter on the geopoint question. With this the pin is still going to show vertically it's just the basemap that's going to rotate.
- If you would like the basemap to remain north up and only the location symbol rotate I would suggest creating a web map and rotating the symbology in the web map, then you can specify the mapSettings parameter and point to the web map item ID for the web map that was created and then that will display in your report.
Thank you,
Zach
ZacharySutherby
Thank you,
Zach
MichelleWilliamsERM
@ZacharySutherby,  Can I remove the arrow, so it's just the dot, on the feature report?
