Survey123 Custom Report Source Code for Web Application
2404
02-09-2018 07:17 AM
JAVIERVARA_SANZ
Is there any way we could get access to the source code utilized by Survey123 to build custom reports? We are trying to create a web application to accomplish the same objective.
Thanks.
JamesTedrick
Esri Esteemed Contributor
Hi Javier,
We are not planning to publish the source code for the API.  The core of the report templating engine is docxtemplater, which has a release available under an open source license.
JAVIERVARA_SANZ
Thanks James.
This helps a lot.
PaulLohr
James,
This blog post states that "...the source code of Survey123 is available as part of AppStudio for ArcGIS under the Apache 2.0 license."
This brings up a few questions.
Is there a web version and an app version of Survey123? App version, as in one that installs on the iOS, Android or Windows platform.
If the answer is yes, is it the web version which the source code can be acquired through AppStudio?
Thank you for any help,
Paul Lohr
Paul Lohr
Lohr Geospatial Services, Inc.
JamesTedrick
Hi Paul,
That blog post specifically refers to the Survey123 field application (the one that installs on iOS, Android, Windows, Mac, Linux).  The web app is entirely different and is not available, though as partially indicated in this thread, it does make use of many open source components as well.
