Survey123 CORS Error when loading CSV
1248
07-01-2021 12:38 AM
imrankhadri
We have arcgis enterprise and portal(10.7). We designed a form in survey123 connect. This form uses pulldata function from another csv file and the form works
fine in the survey123 connect for windows. When we publish form and open the same form in survey123 website, the page gives us this error:
Access to XMLHttpRequest at 'jr://file-csv/FileName.csv' from origin 'https://survey123.arcgis.com' has
been blocked by CORS policy.
Adding https://survey123.arcgis.com to allowed origins in portal setting did not help
What is this 'jr://' protocol and why is survey123 web trying to access file from here when other content is coming from portal sharing?
ZacharySutherby
Hello @imrankhadri
If your ArcGIS Enterprise deployment uses IWA you are likely running into BUG-000125125
Thank you,
Zach
Thank you,
Zach
