Survey123 Connect - readonly expression
7841
8
11-30-2021 02:36 AM
MartaPodsiad_123
I am using Survey123 Connect Version 3.13.249.
I am trying to put an expression in the xlsform readonly field, so the fields are only editable when certain expression is met (image 1). The expression should apply to records already collected in Survey 123 not to the new entries. In general, when the polygon is selected in the dashboard some fields should not be editable when the record has specific request status.
Although, I can publish the survey without an error, once it's opened in the dashboard as embedded content the field is still editable (image 2).
jcarlson
You could hard-code the expression into your URL, perhaps. If you have a hidden null field in your XLS form, say, readonly_bool, you can have your URL go to:
https://survey123.arcgis.com/share/your-survey-itemid?mode=edit&globalId={globalid}&field:readonly_bool=true
- Josh Carlson
Kendall County GIS
MartaPodsiad_123
 Hi, thank you for the suggestion but it did not solve the problem.
IsmaelChivite
Esri Notable Contributor
Hi @MartaPodsiad_123  You may want to try pulldata("@property","mode") it will return 'edit' when the survey is opened in edit mode. You can use this value in your readonly expression.
MartaPodsiad_123
Hi, Thank you for the suggestion. I will give it a go
MartaPodsiad_123
Unfortunately, it does not work.  I want the model name to be readonly if the the status is 'ekfb_rejected'.
This is my xls
After publishing the form I can still edit the model field in the embedded xls form in the dashboard
The xlsform is embedded in the dashboard with the url ending with
/portal&mode=edit&autoRefresh=true&globalId={globalid}
The xlsfrom reads only the entries that have been already collected. It is not designed to submit new records.
Daniel_Perkins
Hi @MartaPodsiad_123 ... did you have any luck figuring this out? I'm having a similar issue. Thanks!
mikaël
Same question here. Conditional readonly field (with formula) does not work in web app. Works in Connect.
Tried with formula version and also if(formula, 'yes', ''). None work.
SarahB
As a workaround, I used the body::esri:visible field to hide the fields that I wanted to be read-only in editing mode (pulldata("@property","mode")!='edit'). I'm having reviewers review those fields in the pop-ups in an Experience Builder app and then follow a link in the pop-up to open the survey in edit mode.
Sorry, realizing now this doesn't work with conditions though.
