Survey123 Connect Question
2407
03-03-2022 07:20 AM
AmandaBeck
Is there a way to have an "other" option in a dropdown (select one) question type where the user of the survey could either select from the dropdown or select other, to then be able to type in said value?
I realize this is doable in the web version of Survey123, but looking for a way to do it in Connect Desktop version.
Thank you!
Katie_Clark
MVP Regular Contributor
In the Relevant column of the XLS form, enter an expression like the following:
selected(${question1},'other')
The value in quotes is the name (not label) from your choice list used for the question referenced
Best,
Katie
If this post helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
Katie_Clark
Very easy to do! All you need to do is add another text question with a dependency where it will only appear if the user select the 'Other' option from the dropdown.
Best,
Katie
AmandaBeck
Thank you for your response. How do I set it so that it is dependent on the previous entry for the dropdown?
Katie_Clark
Best,
Katie
AmandaBeck
Thank you, problem solved!
