Survey123 Connect Issue Creating Webform
365
04-27-2026 08:52 AM
TroyWilten
I have created a Survey123 a few months ago for a work project, and when it was first created it was working, and I was able to pull the Survey up on the web with the webform, but since about a week and a half ago, when I made some changes to the XLS Form I can no longer pull the survey up on the web, and it is giving me the error.
"This survey cannot be opened in the web app. Please contact the survey owner to republish the survey with 'Create web form' enabled. Error: Missing .webform file.
Press here to try to open this survey in Survey123 field app (installation required)."
I have made sure to check if the "Create web form" option was checked, and it was, as well as go through the analyze button to make sure there are no issues, and of course there are no issues causing it to upload. I am a bit lost on where to go from here, we've tried to create the whole survey from scratch, try uploading it on another computer, and even making everything completely public, but to no success.
ZacharySutherby
Hey @TroyWilten
Was the last time you republished the survey from Connect a week and a half ago? If you retry publishing the survey again today do you see the same behavior?
If so can you select the "Files" button in Connect and open the .webform file. Is there an error message in the .webform file?
Thank you,
Zach
