Survey123 Connect Image Question method= camera, browse, map
4120
08-17-2020 10:13 PM
JamieLambert
Hi All,
From this article (Appearance—ArcGIS Survey123 | Documentation), under the IMAGE section (4th paragraph), it says:
"To limit the user to only one or two forms of image capture for annotation, set bind::esri:style for that question to method=cameramethod=browse, or method=map, or any combination of two of them, for example method=camera,browse. The question disables all other forms of providing an image."
Does 'method=' apply to bind::esri:style or body::esri:style? I thought I may have missed bind::esri:style as I have an older form, but when I checked the latest template (Survey123 Connect v3.10.239) I didn't see bind::esri:style there either.
It works when you apply method= to body::esri:style, so is it just a typo in the documentation? Thanks.
Jamie.
BrettStokes
Hey Jamie, hope you're well.
Thanks for identifying this - yep it's just a typo in the Documentation. I'll raise an issue to get this fixed.
Brett
BrettStokes
Brett
JamieLambert
Hi Brett,
Saving a lot of time on my commute these days! Good - when it all worked as expected I figured that was the case. Thanks for getting back to me.
Jamie.
