We created a form in survey123 and we'd like to use that form on our IPhones. In relation to the form, we'd like to link it to a feature service where data from certain fields are sent to the object. Would it be possible for Survey123 to create an object on the map and reference only certain fields back to the object? Most of the fields on the form will not have an associated field to the feature service but we'd still like to capture the information.
Hi Jordon
You can create a survey from an existing feature service as explained under: Generate a survey from a feature service - Use Survey123 with existing feature services—Survey123 for ArcGIS | ArcGIS .
This will create a survey that contains all fields in the feature service, you can then delete the ones you don't need from the xls and publish the survey.
Only the fields/questions in the form will be submitted to.
Thanks
John
