Survey123 Connect Disable Group Collapse
2076
09-23-2022 10:26 AM
BigBry79
Is it possible to disable the ability to collapse a group in survey123 connect? I have set up a survey and used groups to format the layout as needed. I didn't want to use a grid style in this survey but still wanted to have some grid style formatting here and there. I was able to achieve the look and feel needed with this method. However, there are some groups in the survey that I do not want the user to be able to collapse.
BigBry79
Found out that not giving a group a label disables the ability to collapse that group.
James_Whitacre_PGC
This is incorrect, or has changed since this was first posted. Survery123 Connect requires a label for groups now. An error occurs if you do this.
This functionality would be helpful.
