survey123 audio
1238
10-02-2020 09:12 AM
SanjeeviKumar
Is it possible get duration of the audio as separate field which is recorded as part of Survey123 question?
by Anonymous User
Not applicable
Hi Sanjeevi,
No, this is not currently possible. This would require using pulldata @ audio (or similar) which is not currently implemented, to read the details of the audio file and extract those values. If you would like to see this as an enhancement in the future, I suggest you raise it as an idea on the ArcGIS Ideas page for Survey123, or raise an official enhancement with Esri Support.
Regards,
Phil.
SanjeeviKumar
Thanks Philip.
