Survey123 | appearance compact | for specific Users?
1847
09-05-2021 06:51 PM
MichelleWilliamsERM
I have a survey that several people touch, and if would be nice if I could make specific "appearances compact" for the areas that person won't use. Let me know if there's a trick.
Office staff  - Data Entry group
Office staff2  - Assign Bio team group
Office staff2  - Assign Contractor group
Bio & Contractor - Inspection repeat
Office staff 3 - Approves group
Ruth_JiatengXu
Hi @MichelleWilliamsERM
Thanks for sharing here! The appearance of a question is static, but you could set the the visibility of the question dynamically by using body::esri::visible column, here is the doc: https://doc.arcgis.com/en/survey123/desktop/create-surveys/esricustomcolumns.htm#ESRI_SECTION1_7FC91...
The expression in the body::esri::visible has already been supported by field app, and it will be supported by web app in the upcoming 3.13 release (which is currently on BETA website https://survey123beta.arcgis.com/).
Ruth
Ruth_JiatengXu
Ruth
DougBrowning
MVP Esteemed Contributor
It is a bit static but a pulldata to a csv would work.  Grab the username then lookup to see which type they are.  Then use that to hide or show the section.  Could be a pain to keep up to date depending on how many users.  Check out linked csv data.
If you are online then you could do the lookup to a Hosted service.
Hope that helps.
MichelleWilliamsERM
Sorry it took so long to respond to both of you, I saw your replies at a busy moment and logged it as a to-do, that's how long it took me.
I agree: a CSV to bring in the group, and use the body::esri::visible column to trigger each group.
Thank you!
Thank you so much!!!
