survey123 app crashing after deleting draft Android (13)
747
06-13-2023 07:48 AM
GBayMnidooGamiiBiosphere
I keep having an issue with my Android device & Survey123 crashing.
I open a survey, answer a couple questions, quit survey & discard draft. Then while sitting at the summary screen for the survey it immediately crashes and quits the entire app. it only crashes after closing & discard a draft. At no other point in filling our or submitting a survey do I get an issue.
I am not having the same problem on my iOS device.
Device: Android 13
Survey123 Connect: 3.17.55
Survey123 Field App version: 3.17.68
I have tried editing and removing questions with large calculations etc. but it doesn't seem to be particular to a single survey.
Tags (3)
ZacharySutherby
Hello @GBayMnidooGamiiBiosphere
Would you be able to provide a diagnostic log when the crash is reproduced? Would it also be possible to share the XLSForm for the survey to try and reproduce the issue on our end?
Thank you,
Zach
