Survey123 accessibility for visually-impaired?
2615
08-13-2019 04:30 PM
AllenRisley
I have a Survey123 tool created using Survey123 Connect that I would like to have added to my university's campus smartphone app.  The request has been denied because the web development team says that the Survey123 tool does not pass accessibility testing for the visually-impaired.  I'm hoping you can help me resolve the two main issues that have come up:
1) Selection menus and drop-downs do not work with tabbing - Is there a format for select_one or select_multiple questions that can be activate using a Tab key, as a visually-impaired person would do if they were using screen-reader software?
2) Is there a way to add alt text to images used in Survey123 surveys?  I have scoured the documentation and cannot find any reference to this.
If I can't make these changes to Survey123 I will be forced to collect data using Qualtrics, which is a horrible alternative since it cannot collect (precise) geographic location.
Thanks in advance,
Allen Risley
GIS Specialist
Cal State University San Marcos
JamesTedrick
Esri Esteemed Contributor
Just to note, this was discussed with Allen outside of GeoNet - an improvement regarding dropdown was identified that will be looked to be implemented in the future.
ChristopherVan_de_Wyngard
Is Images alt text currently supported for XLSForm when generating reports?
JodyZhengLiu
Hi Allen Risley‌,
The alt text for image is supported now on Survey123 web designer now, you can try it on https://survey123.arcgis.com
Jody Zheng Liu
