Survey Showing Incorrect Map Extent (Map Centric Survey / ArcGIS Hub)
523
06-27-2022 12:41 AM
JGibbs1
I've created a Map Centric Survey in ArcGIS Hub and then edited it in Survey123 Connect - as I need it to point to a particular Feature Service. However once I republish the survey from Connect the extent of the survey is lost and it defaults to a global basemap when viewed as a map centric survey - if I open the survey normally the correct map view shows. Has anyone come across this / have a fix?
All the best,
James
