I've added a constraint on a calculate column that sums all the repeat entries and compares to another total entry. This sum should be within 5% of the total sale price as a check to make sure data was entered properly. All seems to work in connect and survey 123 mobile app, but the constraint is not being honored when submitting the survey from the browser. I'm using Chrome browser and the survey is built in Connect v. 3.13.239.
Is this a configuration issue on my part or is this a bug?
Thanks!
Solved! Go to Solution.
You are making product_prices_sum a string then trying to compare to a number. That if course is not correct. $5 > 4 is trying to compare a string to an int.
You need to get the $ out of there or have 2 fields. You will also want to set the bind:Type to int on the price sum field so that it is treated like a int. Notes all default to string.
That should do it.
Some formulas can be slightly diff in the browser. No real way to help you without seeing the form.
That should do it.
I got it, Thanks so much for the help @DougBrowning !
