Survey 123 Water Quality Sampling
2394
03-22-2021 04:31 PM
ShaneHertzog3
Hello,
Is anyone using survey 123 to document water quality samples? If so how do you have everything configured on the back end?
Thanks
Jim-Moore
Hi @ShaneHertzog3 in case you haven't seen it, there's a Community sample available in Survey123 Connect named Water Quality Survey that might provide a good starting point. It's derived from this Water Quality Inspections ArcGIS Solution (now in mature support).
Best, Jim
DAVIDMCCOTTER48
Does "Mature Support" mean that the Water Quality Inspections ArcGIS Solution is no longer part of the Add-In via ArcGIS Pro?
JamesTedrick
Esri Esteemed Contributor
Hi @DAVIDMCCOTTER48
Yes, Mature Support indicates that the Solution is no longer available for deployment
