Survey 123 URL Parameters causing "String or Binary Data would be Truncated" Error
1925
09-15-2022 03:54 AM
NataliaKaszkowiak
Hi All,
We have a simple Survey 123 form set up, that is launched from a pop-up window in the web map. Pop up window contains a text, which in fact is a hyperlink.
In the URL we have set up some parameters, one of them is an info from selected feature (owner of the pop-up).
It all works fine, when filling up the form on the web version. However when submitting edit via Survey 123 App on a tablet, this particular filed is being truncated.
Both, the source layer and target layer for this info, have Codes (01,02) set and labels.
Source layer is a String(256), target is String (10).  If the code is 01 and 02, I would expect to "fit" in 10 character space but it looks like the URL's parameter tries to insert an actual label.
Below is our URL:
arcgis-survey123://?itemID=xxxxxx:PARENTDUCTID={GlobalID}&field:FUNCTION_={FUNCTION_}
Does any one had similar issue?
ChristopherCounsell
MVP Frequent Contributor
The URL scheme by default will pass the domain description, not domain value. This makes sense as we would want the field to show the useful label in a pop-up in normal circumstances.
You can try creating a custom arcade expression of the below and then referencing the expression in the custom URL pop-up
DomainName($feature, 'fieldName')
arcgis-survey123://?itemID=xxxxxx:PARENTDUCTID={GlobalID}&field:FUNCTION_={expression}
https://doc.arcgis.com/en/arcgis-online/create-maps/configure-pop-ups-mv.htm#ESRI_SECTION1_BE0D1CA2E...
Please don't forget the kudos 🙂
