Survey 123 Attachments
2394
09-24-2019 10:20 AM
Wade_Adams
I have a published survey on a web page and want to allow users to attach files. Is it possible to attach different file types to Survey 123? (for Example PDF)
BrandonArmstrong
Hi Wade,
If the survey was created using the Survey123 Web Designer at survey123.arcgis.com, then the ability to add 'file' question is available.  This would allow a file (like a PDF) to be attached to the survey when filling out the survey using the web app.  So, you must create the survey using the Web Designer and submit the survey using the web app (when including a 'file' type question)
More information on question types here...
Quick reference—Survey123 for ArcGIS | ArcGIS
Best,
Brandon
BrandonArmstrong
Hi Wade,
Best,
Brandon
Wade_Adams
Thanks for the info.
