Survey 123 Attachments corrupted when emailed using Power Automate
668
11
4 weeks ago
MichaelTorbett
I have a power automate flow that has worked fine up until a few weeks ago. It takes information from a survey 123 form and sends an email with an attachment. The flow executes successfully, but now, the pictures will not open from a email.  The workflow I use for attachments is here
Has anyone else recently had an issue with their attachment coming in corrupted? I'm wondering if this is from a recent update since my flow has not changed.
I've attached a screenshot of the flow I use. I have a case with ESRI Tech Support open as we speak.
Michael
MichaelTorbett
I will certainly keep that in mind about the modern designer. Thank you for your help with this!
AlfredBaldenweck
MVP Frequent Contributor
See I prefer modern designer because the old one wasn't finding my sharepoint sites when I was trying to do things.
