Survery123 Date function
962
06-09-2022 02:18 PM
eyohannes
I'm attempting to create an inventory that lists when certain projects are slated to start/end versus when they actually started/ended.
Certain projects have already concluded. For such projects, their exact end date is known so I used the "Date" function. However, certain projects are still ongoing - thus I'd also need an option that says "ongoing/ in progress". If at all possible, how might I have the date option and a "ongoing/in progress" option in the same cell?
ZacharySutherby
Hello @eyohannes
Due to how data is stored in ArcGIS it's not possible to store text in a date question. If you want to store both text and dates in the same question it would be best to use a text question and then have the dates calculated or have the user manually input a date in the text box.
Thank you,
Zach
ZacharySutherby
Hello @eyohannes
Thank you,
Zach
