I'm creating a survey where I want all the fields to be required but also have the ability to save the survey in drafts if all the required fields are not filled in. This would allow you to start collecting in one form then be able to start another form. Is it possible to allow the survey to be saved in drafts but because some required fields are not filled in, allow it to not be sent until the required fields are done? Thanks!
Hi Gillian,
Having a field be required does not prevent the form being saved to the Drafts folder.
Hallo James,
I have the same issue!
I can't save a survey as concept (draft) with an empty required field !
