Summary Section, Where doesn't work with Query to Field, Get "cannot be found in the current parsing scope"
1022
01-02-2026 07:10 AM
Carrie2025
Hello - I am putting together a report where I am trying to pull a list of all previous inspections in a summary report.  the inspections table is linked as a related table using a GUID Field (In my report, called PERM_ID).  From what I read, this should be possible.  However, I keep getting a "Cannot be found in current parsing scope" error.  I know the "PERM_ID" field is correct, it works in other places, as well as in the summary section when not used in as part of the where clause.
It works if I hardcode the value in in - it works if I don't use a where statement, and according to documentation, It should work.
I'm not sure what I'm missing - I've uploaded the report I'm using (Its currently missing the !important to pull all matching value)
Neal_t_k
MVP Regular Contributor
This might be worth a shot, not sure if it will work in the sql.
https://doc.arcgis.com/en/survey123/browser/analyze-results/featurereport-repeats.htm
${#PermitInspections_test|where: "PERM_ID ='${<mainlayername>.PERM_ID}'"}
or
${#PermitInspections_test|where: "PERM_ID ='"+${<mainlayername>.PERM_ID}+"'"}
VenkataKondepati
Honored Contributor
This is a report parsing-scope issue, not a bad field.
In Survey123 reports, the where: clause on a related table runs in the child table’s scope, so the parent field (PERM_ID) isn’t automatically visible. That’s why it works when hardcoded but fails when referenced.
Fix: reference the parent explicitly (or assign it first):
${Inspections | where:"perm_id='${@parent.PERM_ID}'"}
(or assign PERM_ID to a variable and use that).
Related-table queries can’t “see” parent fields unless you explicitly pass them into scope.
Regards,
Venkat
Follow me on: LinkedIn
If this response helps or is the solution to your post, please consider marking it as a solution
Neal_t_k
or
Carrie2025
Hello There! Thank you so much for your help - I ended up using partially @Neal_t_k solution, but @VenkataKondepati pointed me in the correct direction and gave me the piece that I was missing.  I ultimately went with this:  ${#PermitInspections_test| where:"PERM_ID = '"+$mainlayer.PERM_ID+"' !important" |orderByFields: “OBJECTID DESC”}, inside a table, and it works.  Now, I just need to wait on my user to tell me exactly what he wants in this report!   Thank you so much for your help!
VenkataKondepati
Honored Contributor
Thanks for the comments @Carrie2025 . I am glad it worked out.
Regards,
Venkat
