Submission url no longer compatible after enterprise and sde updates
613
12-30-2022 12:16 PM
ChelseaTabor
My organization recently updated to enterprise 10.9.1 and completed a move to a new sde server, with the addition of user roles. After the updates users have reported issues with submitting a survey through survey123, and I get this error message in connect: 'The custom feature service submission_url is not compatible with this survey'.  The survey has been using the same submission url successfully since I published the survey over a year ago.  I suspect this error may be due to the user roles we're now using, but I'm not sure.  I've tried republishing the service with no luck.
MichelleWilliamsERM
Following
GaryBowles1
Enterprise 10.9.1 no longer will no longer display feature services published using ArcMap. If the original feature service was published from ArcMap, this might be the issue. Try republishing using Pro and see if this resolves.
--gary
