Submission URL error
2992
07-19-2016 09:57 AM
CarlHolt
Table gi_repeat not found? Is it referring to the survey or feature layer?
IsmaelChivite
Esri Notable Contributor
It looks like you  have a repeat in your survey called gi_repeat. Survey123 Connect is trying to find in your Feature Service a table with the same name. You will get the warning above until your Feature Service includes such a table. Alternatively, you can change the name  of your Repeat in the XLSFile to match the name of the Feature Layer table in your Feature Service.
IsmaelChivite
CarlHolt
The field gi_repeat was given to a begin repeat field type in the xls form.
