Stakeholder View Issue
1402
03-04-2020 02:12 AM
by Anonymous User
Not applicable
Hi All,
I have edited previous fields and created some new fields into an existing form and published successfully. The form is shared with a number of field assessors. The issue I got is that the changes are applied only to me and I can see all the changed fields and works perfect but other users have the old form and no change has occurred into their form. Additionally, they can view the data by going to data tabs.
I realized that the change has not been applied to the stakeholder view. My question is if I delete the stakeholder view and republish my form, does it affect my current data and form?
Wali
Shwu-jingJeng
Hi Sayed,
It looks like you are having the issue as described in this tech support article:
Problem: Survey results are not updated in Survey123 for ArcGIS
Please follow the article solution to simply unshare/reshare the survey permission after deleting the stakeholder view. You should not need to republish the survey.
by Anonymous User
Not applicable
Dear Shwu-jing Jeng
Many thanks, I have solved this issue the way you explained.
