SQL Triggers on Feature Classes for Survey123
1329
11-20-2019 02:21 PM
vijaybadugu
I created the trigger to access information from different tables and update in the feature class ( enabled with Attachments)  and sending email notifications in trigger itself. when i try to insert/update records from SQL Server and ArcMAP and ArcGIS Pro . it is working as expected. But when i try to insert/update records from Feature Service or Survey 123 app . It is giving errors . if we keep insert trigger , it is working as expected. if we try to append UPDATE trigger to it. it is throwing error. my obeservation is whenever inserting records using REST Feature service , The update trigger is also firing. Why ? How to overcome with this issue ? The feature class is not versioned.
IsmaelChivite
Esri Notable Contributor
Hi. It seems like this question is more appropiate for the ArcGIS Enterprise‌ GeoNet group. Survey123 is  using a feature service to add a record. Understanding why the feature service is not adding a record is key.
TL2
@vijaybadugu   Did you every get an update trigger to work on an archived table in sql?
