Sorting Fields in a repeat Report Template
1826
06-05-2024 03:35 PM
DeborahDennison
Hello S123 team mates, I can use some guidance on how to sort fields within a Repeat Section in a Report Template (Word Document).
Is it possible to use the 'orderByFields' in a repeat section?
Here is the syntax that does not work for sorting:
${#repeat_tree_survey | orderByFields:"tree_tag_id ASC"}
Survey Site:             South Watershed Monitoring
Tree Tag ID:            ${tree_tag_id}
Survey Date:            ${Tree_Survey.survey_date}
Tree Species:           ${tree_species}
Your thoughts and tips are greatly appreciated!
Debbie
Tags (1)
abureaux
MVP Frequent Contributor
You can use sorting in the Feature Report just fine for a repeat. See Report templates
${#defects | orderByFields:"state_name ASC, pop2000 DESC"}...${/}
EDIT: forgot to mention, but please ensure that your field (tree_tag_id) is a number and not a number stored as text.
TrafficOpsGIS
Please see screen shot of how to format table in word doc in order to accomplish.
