The option to share surveys publically has disappeared (i.e. Everyone (Public) no longer appears as an option in the Collaborate tab). Has this option been moved elsewhere? It was previously visible on my surveys but now I can only share with the poeple in my organization or groups.
Hi Shira,
Have there been any changes to your organisation's settings? If you're an administrator, can you head to Organization > Edit Settings > Security and ensure that Members can share content publicly is enabled?:
If you're not an administrator, check with an administrator that your role allows you to share content with the public.
Carmel
Hi Shira,
Carmel
That is exactly what happened. Thanks!
