Set Rule in XLS Forms
2849
05-30-2019 08:40 AM
AprilChipman
Is it possible to set a rule in XLS Forms like you can in the web version?
I've got a Select One question, and I'd like to show other questions depending upon the answer to the Select One. I've looked at Cascading Selects, but I don't think it's going to do what I would like...
DougBrowning
MVP Esteemed Contributor
You want the relevant column.  You can hide the field based on it eval to true.
DougBrowning
AprilChipman
Thank you, Doug! I knew I was just missing it somewhere!
IsmaelChivite
Esri Notable Contributor
