Set default value for Single Select field in Survey123
606
02-04-2026 10:10 AM
Bud
Legendary Contributor
Is there a way to set a default value for a Single Select field? (from within the Survey123 website > design mode)
In design mode, I tried clicking the radio button beside a choice:
But in preview mode, the choice did not get automatically selected.
If clicking the radio button in design mode doesn't set a default value, then what does it do?
Neal_t_k
MVP Regular Contributor
What you describe should work, Did you try saving and reloading?
Bud
I tried saving and previewing, but no luck. The form isn't published yet.
ToddW_stl
this may be expected , but I'm not 100% sure.  Preview a survey says preview "displays the survey as it will appear to users, although without simulating any rules you may have put into place".  I would guess that publishing would lock that setting in and the default should work.
ZenMasterZeke
Works for me...
Created a blank survey in web designer at S123. Survey published to AGOL, not Enterprise.
