Set Default Location for Map on survey
1349
12-26-2021 08:44 PM
MichelleLuckes
All,
I'm creating surveys for individuals that may or may not have an internet of connection of any kind. How can I set my headquarters location as the default point for the location question on my survey?
Thank you
Kanin
by Esri Contributor
Hi Michelle,
Could you please enter the Latitude and Longitude pair of your HQ's location in the default column of the geopoint question in the XLSform (using Survey123 Connect) and see if this works for you?
 Best regards,
Kanin
If this answer solved your question, please mark it as "Accept as Solution" to help others who have the same question.
