Selectable map feature in a survey123
4433
6
03-10-2024 08:27 PM
JohnMorgan
Hello,
Is it possible to use a map survey question where the participant selects features on the survey question map and submits those features selected? For instance, selecting three buildings that meet specific criteria. If so, can you please let me know how to configure this?
Derek
abureaux
MVP Frequent Contributor
Essentially you'd:
  1. Set up a Web Map to contain all your desired layers and look the way you want
  2. Select the layer you are interested in (your Web Map may have more than one layer) and then build a popup for it using the "Web form URL parameters" as a guide on formatting the URL. The layer you are building this popup for will provide the data that populates the S123 questions.
  3. Build an Experience (aka, use Experience Builder) your new web map
  4. Deploy the Experience
Now, users can access the Experience and launch into S123 via the web map.
abureaux
This would work best using either Field Maps or a Web Map to start your survey and then launch into Survey123.
Check out these resources:
JohnMorgan
Thanks for the response and info. It makes sense to integrate with other apps such as Field Maps or a Web Map. I was hoping for the functionality to be able to add a selectable map feature to Survey123.
Thanks, Derek
abureaux
Sorry, I neglected to mention pulldata(@layer). That may also be of interest to you.
JohnMorgan
Okay, I think I understand. Could I, for instance, use the "data-centric" widget in Experience Bilder on a map or within a Survey123 survey?
abureaux
Essentially you'd:
JohnMorgan
Thanks for your feedback. This makes sense and solves my issue.
Cheers,
Derek
