Select vibration on device
1562
09-03-2019 09:45 AM
RonKnepper
So I've been pulled to other work the last 18 months and getting back up to speed on the changes since.  Lots of cool new things but I have to reuse an older survey which I've edited fine.  In testing on the device I notice all drop down, multi-select, and image captures have a quick vibration when you select.  I cant seem to see where I can turn that off?
by Anonymous User
Not applicable
Hi Ron,
Yes, you can turn Haptic feedback (the vibration you are noticing) off in the Accessibility settings option in the app Settings menu.
Phil.
by Anonymous User
Not applicable
Hi Ron,
Phil.
RonKnepper
Perfect thank you, I need to get back into all the updates the last 2 years since things move so fast.  I just needed to get this survey out and running quick.  I was thinking there was something in publishing but make sense it is local on the app.
