S123 PDF Reports with No Checkboxes
2179
23
06-16-2026 05:01 AM
CRossNSDA
I have noticed, just today, that all of my S123 reports that use the checked / checkbox option are not rendering at all when the PDF option is chosen. Example, ${EXT_GENCOND | checked:"ACCEPTABLE"}.
This just started happening today and all of my various reports are acting the same way so it is not on the report template side.
When I choose the DOCX option it works fine.
This is not a workaround that I want to deal with as I have many power automate flows that need to have the reports sent out as a PDF.
CRossNSDA
Our PDF reports were mostly generated via Power Automate flows so after hearing about this, I went in and changed our flows to generate a DOCX and then used a Convert to PDF flow connector and it will be my solution until the fix happens. I know this will not work for likely many folks but it was a fairly quick and easy interim solution for us.
EdenPettigrew
Following this too, my docx download isn't working either but that may be unrelated.
Ruth_JiatengXu
Hi @EdenPettigrew ,
This might be an different issue, could you provide more details related to the docx dowload? e.g. error message shown in the job history
Ruth
Ruth_JiatengXu
Hi everyone,
The fix is now available on production site. Sorry for the inconvience, we will imporve the test coverage to prevent this kind of issue. We have also communciate within the team to ensure the critical issue can be fixed more quickly.
Ruth
