S123 Form Logical Expression
1605
09-11-2023 06:41 AM
kapalczynski
Is there a way to Make a Field in a form Required based on the value of another field...
ex.
If Question 1 is Yes -- Question 2 is Required
If Question 1 is No -- Question 2 is NOT required.
TL2
selected(${question},"Yes")
TL2
TylerGraham2
To add to that, make the second question required and put the formula in either the "Relevant" column or the "body::esri:visible". It will only show the question when the requirement is met and then a response will be required.
kapalczynski
Fantastic.... Thank you
