Rules for Rookies
949
01-31-2020 01:35 PM
ValerieAtalig
I am creating a site inspection survey for buildings. I set up a numeric questions asking "How many areas in the building?". I have another group of questions for each section of a building. I created the same set of questions for up to 10 "Areas". How do I link the numeric response to the number of groups the data collector is able to see? For instance, if a data collect answers "4", then only 4 groups of "Area" questions become visible.
JamesTedrick
Esri Esteemed Contributor
Hi Valerie,
Have you modeled the group of questions for each area as a repeat?  This would be the way I would recommend this; you can then set the repeat_count to the number of areas and match the number of collections to the entry. See Repeats—Survey123 for ArcGIS | Documentation
