Retrieving a repeat section through a webhook
2625
6
10-17-2018 02:05 PM
ZacharyCravens
I have added a webhook through Zapier to my survey. It is pulling in new records, except those in the repeat section of the survey. Is there a way to retrieve the data from a repeat section through a webhook?
JamesTedrick
Esri Esteemed Contributor
Hi Zachary,
Are you submitting data using the field app or web app?  There is a known limitation with the web app at this time.
AnuSawant
Hi James,
I am trying to add webhook through Integromat. While setting up the email notification I cant find records (fields) listed in the repeat section in my survey123. Is it not supporting to repeat(related) table? I am using field app to send the record.
Anu
joerodmey
I am having this problem. Was this resolved in any current versions? If not I'm looking for a workaround to access my related records. My preference is to access the related records via Integromat and make a Survey123 report using this data James Tedrick
ZacharyCravens
Hi James,
I had been submitting data through the field app. Although, I have since found a work around using other software and so haven't been attempting this method for awhile. I appreciate your reply.
joerodmey
Zachary Cravens What was your workaround?
ZacharyCravens
I ended up using the AGOL API to pull the data into R as needed. See GitHub - yonghah/esri2sf: Scrape features from ArcGIS Server REST API and create simple features dat...
