I created a survey where I had a field that was set to "Null" that was used in a pulldata() calculation, unfortunately I forgot to add the csv file to pull from into the media folder before publishing and have had a bunch of data (500+) records uploaded with a blank field where the calculation result should be. When then record is opened from the sent Items on the device the Null values are still populated leading me to think that there should be some way of getting the data off the device. I thought if I republished the form with the csv file in place that users could open edit and resend the survey, however it appears that the formatting of the previous version of the form is still in place for those records. Any thoughts on the best way to approach this problem would be greatly appreciated.
Hi Brent,
Are you able to provide a copy of your xlsx form, including the csv file used in the pulldata() calc so we can look into this further.
Regards,
Phil.
