Republishing Error: "User Folder does not Exist" (Critical, Code 400)
2137
11-03-2022 09:49 AM
Bryan_Wade
I recently moved a survey into a new folder and deleted the old folder. When republishing did not work I went into the Iteminfo file in my survey folders and changed the ID number to new the folder. I then saved the Iteminfo with the new information. When I went to republish the survey I got the error message "User Folder does not Exist". When I go back to the iteminfo file for the survey the folder ID number has changed back to the old ID number. Am i missing a step in this process or do I just need to save my xls files and republish the survey and the corresponding surveys all over again.
IsmaelChivite
Esri Notable Contributor
It looks like Connect and ArcGIS are out of sync.
Clean up your ArcGIS folder.
Create a new survey from your XLSForm and publish again
IsmaelChivite
Bryan_Wade
Ismael,
Thank you, that worked. Now i am getting a GlobalID error message when I embed my review surveys into experience builder.
The GlobalID is set to true for editing in the feature service.
