Reports: Map Filters: Use field as variable in where clause?
836
05-23-2025 09:09 AM
AlfredBaldenweck
MVP Frequent Contributor
Map expressions—ArcGIS Survey123 | Documentation
I'm trying to use a map question in my report. In it, I'm attempting to filter down layer 3 where its field "grnduuid" is equal to this survey's inspuuid.
Here is an attempt:
${$map | map: “3d6eb5778a174e55ad2a1a75783eeade” | mapFilters: “’196ef2e95d0-layer-3’: where=grnduuid=inspuuid”}
Here is another:
${$map | map: “3d6eb5778a174e55ad2a1a75783eeade” | mapFilters: “’196ef2e95d0-layer-3’: where=grnduuid=SURVEY_TABLE.inspuuid”}
Here is another (failed in syntax check)
${$map | map: “3d6eb5778a174e55ad2a1a75783eeade” | mapFilters: “’196ef2e95d0-layer-3’: where=grnduuid=${inspuuid}”}
ditto for
${$map | map: “3d6eb5778a174e55ad2a1a75783eeade” | mapFilters: “’196ef2e95d0-layer-3’: where=grnduuid=@inspuuid”}
What gives?
How can I call a variable in a where clause?
AlfredBaldenweck
Figured it out from @CarissaPhantom's post .
Proper way to go is:
${GeoPoint Question in Survey  | map:"ITEMID"| mapFilters:"'18fe96a428a-layer-22':where=Numb='"+ProjectNumber+"'"}
@CarissaPhantom: If you post this exact post here, I'll change this answer from being the solution to yours so you get the credit. Thank you for figuring this out.
AlfredBaldenweck
