Report template error
532
05-22-2025 07:59 AM
WVCAIT
I am trying to create a report for a survey that has approximately 40 records.
When I try to create a sample template in manage templates, I receive an error message that states, “An error occurred while saving the report template” The error code is 504.
I was able to create a sample report template in two other surveys, so the issue is with this survey.
This was a known issue on post Solved: Survey123 Create Sample Report Template Fails; Err... - Esri Community, but I am still having this problem.
I have tried the suggested work arounds to no effect.
