I am trying to Generate a report using Survey123, failing to do so, getting an error message:
"Failed to print map for ${Report_point}. Failed to load web map: Unable to load https://arcgis.thiess.com/arcgis/rest/services/TestPublish/sonReport/FeatureServer/0?f=json status: 0"
I am uisng ArcGIS enterprise login and SQL database.
Kindly help? Please let me know if need more clarification.
Hi Vaibhav,
Is the ArcGIS Enterprise site accessible from the internet (i.e., can you log in to ArcGIS Enterprise when not in your company's network or VPN'ed in)? The Feature Report service only supports Enterprise installations that are accessible from the internet.
Its external facing
Did you specify a map by id in the template? Could I ask you to try a sample that does not have a map in it to make sure that is created properly?
Hi James,
Thanks for taking interest in the query.
Yes, It did work if I don't have a map in the template. But my requirement as such requires one (map). I tried with specifying the Web map by id in the template, hence it keeps giving me the follwoing error:
"Failed to print map for ${Report_point|mapSettings:"2df5cba97dc940b7998210cebae90956":100000|size:400:400}. Failed to load web map: Unable to load https://arcgis.thiess.com/arcgis/rest/services/TestPublish/sonReport/FeatureServer/0?f=json status: 0
Please see details in the recent tasks panel
Hi Vaibhav,
The service mentioned in the error report is secured - can you make sure that it is shared for the user submitting the report?
Today, when I sign in to the portal (on-premise) in the Survey123 website (As ArcGIS Enterprise user) when I click on feature report (which has changed from Report-beta to Feature report) through an error when I generate report says - Your ArcGIS Online subscription is not active. Contact your organization administrator for assistance.
I'm having this same issue! Mine says "You do not have access to this feature. Required privileges: generate feature report". I own the survey, and don't see anywhere to change these permissions. Did something get reset with organization privileges?
Hi Anne,
The Feature Report capability now requires an additional privilege which does not apply to a custom role in ArcGIS Online by default. Please find more information in our blog: https://community.esri.com/groups/survey123/blog/2019/06/28/world-ufo-day-release-35
Feature Report generation is available as a premium ArcGIS Online service. Users who want to use the service will need to be granted Feature report privileges. By default, all roles and role templates included in ArcGIS Online include this capability, but if you use custom roles you will need to turn it on. This can only be done by an administrator of an ArcGIS Online organization by including Feature report access to the custom member role.
Zhifang
Hi Vaibhav,
This is a bug for ArcGIS Enterprise and has already been fixed on the Survey123 website, would you please try again?
Zhifang
